IC-409 Fiery and C550 Bizhub Controller QUestion
  • bungapads
    • May 2009
    • 69
    I have set up and used for years an Ic-409 Fiery controller on a C550. I can through an IP address go right into my IC-409 Fiery. However, even after following all instructions and install information, i am not able to log into Page Scope through the direct ip address for the machine. I have verified all settings (unless i missed something). What has to be done to use page scope? does it have to be installed? settings on the machines? any help would be very helpful
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: IC-409 Fiery and C550 Bizhub Controller QUestion
    What is the ip address on the copier?
    how is the machine wired to the network? (1 drop to fiery or 2 drops 1 for fiery and 1 for machine)
    What cables are plugged in between fiery and machine?
    • bungapads
      • May 2009
      • 69
      I have two drops one from RJ45 in the wall to Machine and one RJ45 cable from wall to FIery. No other cables between Fiery and machine. I have set up as Method A in the set up.
      I have assigned two different IPs. One to the Fiery and one to the Machine. I have verified multiple times that each device, Machine and Fiery have different IPs and I have verified IPs are live and working. I can connect to Fiery IP, I cannot connect to Machine IP
      Ron
      • bungapads
        • May 2009
        • 69
        I made some headway. I checked the cables and it looks like one connection was bad. I replaced the cable and now i can get to the machine. HOwever, i wonder if the PageScope Software is gone (erased from my last nvram reset? I get the following when i put the ip address in for the machine http://"ip address"/wcd/index.html. The "ip address" I typed in to keep my ip protected. I do not want to give out this number. Afraid someone may hack.
        Do you know if when i did a reset i have to somehow reinstall page scope? if so, do you have the software to install or know where i can get it with instructions?
        • mx6turbo89
          • Oct 2013
          • 154
          That address is what you see when you're at the main index page. Is it a blank page? Which browser are you using? You might try another such as Chrome.
          • bungapads
            • May 2009
            • 69
            Yes it is a blank page
            • bungapads
              • May 2009
              • 69
              I was in Chrome and then IE new version, blank page on both
              • mx6turbo89
                • Oct 2013
                • 154
                What level of firmware is on the machine?
                • habik
                  • 2013
                  I use Firefox and never had issue on ANY device.
                  Firmwares HERE
                  • bungapads
                    • May 2009
                    • 69
                    Fanatastic. I installed Firefox and was able to browse right to Pagescope. Thanks Thanks Thanks
