koica 250 paper curls at exit
  • DOE
    • Mar 2010
    • 258
    Konica 250 that every 4 pages or so a copy will exit and roll up. moisture in paper usually causes this but it does it with fresh paper. copier has a receiving tray, no sorter. will a worn fuser roller cause this to happen. after a few roll up it causes copier to jam. thanks for your opinion.
  • mo0651
    • 1054
    Re: koica 250 paper curls at exit
    Are you talking the B/W 250 or color C250? Some of these had decurling rollers in them when shipped. and you removed them when you installed a finisher. But if you removed finisher, you would
    get curling paper at exit!
    • copyrooks
      • Oct 2013
      • 208
      Make sure the orange rollers on the fusing exit are not gone or missing.
      • Hansoon
        • Sep 2007
        • 3374
        Yep, as said. When on the Mono Bizhub-250 the grey decurling rollers in the fuser unit are missing than you have this effect.
        You might consider this or a similar solution which worked very well for us:
        Hans
