Bizhub C360 intermittant duplex jams
  • Desert Rat
    • May 2008
    • 1089
    The call was for duplex jams. If I push in on the right side door, it runs fine. So I figured out a way to shim that assembly
    that feeds paper to the fuser, up tighter and the jamming sub-sided for awhile. But it is coming back.
    I recall hearing about a Mod for the door.
    Can anyone tell me the part number? I'm sure the customer would appreciate it, and I would too.
    DR
  • tech51
    • 846
    Re: Bizhub C360 intermittant duplex jams
    Are all the catches that hold the door closed ok?
    The one at the top on the machine side is prone to breaking and causing jams.
    Just a thought.
    • Desert Rat
      • May 2008
      • 1089
      tech 51,
      Thank you for that suggestion. Although I did not specificly check for cracks, I will on my next trip.
      But it did seem to latch OK, but that would account for the extra play.
      I will look at this later today.
      Thanks again
      DR
