Bizhub PRO 950
  • Toxic
    • 697
    Bizhub PRO 950
    Hi,
    I have one 950 on the field,lastnight it works normaly,shutdowned,this morning it shows error C-8407 at first starting and remain that error after several tryes.
    I cant find anything about this error,service manual or google, it is strange to machine show error which does not exist in service manual,it never happened to me before.
    Somebody have some ideas?
  • Service@PRT
    • Oct 2016
    • 181
    Re: Bizhub PRO 950
    that error is for higher model like 1000+ series this one is ps312
    C-8407 Original skew sensor /Fr (PS312) abnormality. 18-4
    tho its the same c-8406 on 950 this one is ps313
    C-8406
    Description
    Original reverse/exit sensor (PS313) abnormality.
    Causes
    Confirming the sensor operation Confirmation of the wiring harness and the connector Original reverse/exit sensor (PS313) DF control board (DFCB)
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
    • Toxic
      • 697
      Re: Bizhub PRO 950
      Yes,you are right.
      abnormality.
      Cleaning of the sensor's mirror
      I found that info in revised service manual after somesearch ,they add description for this error.
      I just removed sensor,reconnect, clean reflection mirror and sensor, no more error.
      Thank you anyway
