magicolor 4690 0f50 malfunction
  • brent
    • Nov 2008
    • 1212
    ok like it says I have a magicolor machine around 30 k on it it has the 0f50 code
    I can not seem to reset it.. I have the maintenance manual on it and it is as clear as mud
    its a sensor ps7 or prcb the sensor is mentioned only like 3 times in the service manual
    and it is called an ohp sensor period there is a location it seems on page 323 but that's it
    any thoughts or ideas on this? thanks all
    brent
  • copyrooks
    • Oct 2013
    • 209
    Re: magicolor 4690 0f50 malfunction
    I know this isn't the same model but i had this code a few times on a few bizhub c3110s. I ended up replacing the imaging unit of the color of the sensor mentioned on the manual. So far no callbacks for the same code once changed. Hope this helps good luck.
    • mo0651
      • 1054
      It is an optical sensor, have you given it a good cleaning in that area?
      • brent
        • Nov 2008
        • 1212
        I have not yet. Because the service book is so vague. I've been trying to just diagnose the problem. I didn't think it was in any drum unit
          • 14512
          Look in the parts manual. It give you a very good shot of where PS7 is located.
