Bizhub 223 code 8101
  • jonpaul
    • Jul 2014
    • 59
    we have a biz 223 that is showing code 8101 the service manual is not very forthcoming has anyone a simple answer,thank you
    • 14614
    Re: Bizhub 223 code 8101
    Service manual is pretty detailed.
    19.5.74 C8101: Before reading pressure welding alienation mechanism trouble
    Relevant parts
    Reading roller release motor (M3)
    Reading roller release position sensor (PS12)
    DF control board (DFCB)
    Step Action
    WIRING DIAGRAM
    Control signal
    Location (Electrical
    component)
    1 Check the connector between M3-relay
    CN5-DFCB J15 for proper connection and
    correct as necessary.
    2 Check the connector between PS12-DFCB
    J15 for proper connection and correct as
    necessary.
    3 Check the connector of M3 for proper drive
    coupling, and correct as necessary.
    4 PS12 I/O check, sensor check DFCB J15-3 (ON) DF-621 G-1
    5 M3 operation check DFCB J15-4 to 5 DF-621 G-2
    6 Change M3 — —
    7 DFCB F8 conduction check — —
    8 Change DFCB
    Also check for something that may be stopping the rollers from pressing or releasing.
    Hope this helps.
    PS. The issue is with the DF
    • CraigW
      • Dec 2010
      • 417
      DF-621 ?
      Likely paper left from a jam. Those feeders are very tough to make reliable from what I've seen.
        • 14614
        Originally posted by CraigW
        DF-621 ?
        These are my least liked DF.
        • allan
          RTFM!!
          • 5462
          Then there is a B36 DF.
          The DF-621 can take a beating. Except the plastic the sun deforms it like nothing i have seen before.
          Whatever
          • CraigW
            • Dec 2010
            • 417
            If you are scanning the improved "paper present" actuator (with the magnet in it) is a must have.
            • mx6turbo89
              • Oct 2013
              • 154
              If you want something easy to try first, install firmware G00-D6. It addresses the C8101 issue.
