bizhub C353 C-E002
  • Guest
    bizhub C353 C-E002
    dear all ,
    i removed MFP board and reinstalled it again after fixing the network port
    the first problem i faced is : serial number needs to be entered , and one of our technicians fixed it ,
    but after that and just after turning on the printer i get the error C-E002 !
    have you ever faced this problem , any suggestions on how to solve this would be appreciated
    edit :
    in service manual it says to try this :
    Service Mode > State Confirmation > Memory HDD Adj. > Up Ver
    but start button doesn't change to blue !
  • Gaffers01
    • May 2011
    • 335
    Re: bizhub C353 C-E002
    You probably need to tell the machine that the HDD is Installed and then try again.
    Service mode>System 2>HDD change to installed.
    i havent looked at this model for a few years but i think that is the process, like the newer machines.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      Originally posted by hugohug
      dear all ,
      edit :
      You may need to format the hard drive.
      Back when these machines were still in service this was a common problem on machines that had fax kits that were used heavily. Would need to be done once a week once a certain number of faxes were received in the life of the machine due to a firmware bug. Total initialisation fixed it when this started. Later versions of firmware may of fixed this but, we don't service them anymore so I don't know.
      • Guest
        i haven't looked at this model for a few years but i think that is the process, like the newer machines.
        thank you for replying
        i tried this and i could do the Memory HDD Adj. > Up Ver and the result is NG also i get the same error C-E002
        also when i reboot the machine i the hdd status changes back to not installed !
        the HDD won't format , i changed with other one but still the same problem !
        unfortunately i don't have a CF card to update the firmware or to initialize it !
        • Rvale
          • 83
          had many of those myself, to start with: What you mean by fixing the netwok Port?
