b250 not taking paper
  • vamaturure
    • Dec 2016
    • 25
    [Misc] b250 not taking paper
    hie tecs
    i have a bizhub 250 which is failing to take more than 30 papers in its tray. if you put a ream of bond it will make some noise and the give a code error of c0202.
    how best can i tackle the issue.
    the problem is said to have started after a long day of printing abt 4k copies.
    thanks in advance
    • 14943
    Re: b250 not taking paper
    Have you tried anything to fix it yet? C-0202 is a lift error.
    • copyrooks
      • Oct 2013
      • 210
      look for paper behind tray 1.
      • vamaturure
        • Dec 2016
        • 25
        notyet
        • vamaturure
          • Dec 2016
          • 25
          there is nothing there
          • REGSIS
            • May 2016
            • 435
            There's a motor back there with a plastic clutch that could be broken. I think that you can switch positions of motors (should be the same); remove both trays and replace lift motor from tray 1 to tray 2 and vice versa.
            Now if it that drawer work OK and the other drawer produce an error - order a new lift motor.
            • vamaturure
              • Dec 2016
              • 25
              thanksregisitturnedouttobeahousingofthemotorhadbro kenmaybeduetoimpactcauesedewhenclosingthetray
                • 14943
                Space bar is usually at the bottom of the keyboard in the middle. For future reference. lol
                • vamaturure
                  • Dec 2016
                  • 25
                  kkkkkk it wqas not responding.
                  • darry1322
                    • Oct 2010
                    • 817
                    Ithappenstomefrequentlyonthissite.
                    It happens to me frequently on this site. I have to type in Notepad and then cut and paste into the editor pane because my spacebar doesn't work in the editor.
                    • vamaturure
                      • Dec 2016
                      • 25
                      that makes the two of us.
