Bizhub C35 random thin horizontal lines on copies
  • GOA
    • Jan 2017
    • 14
    To whom it may concern,
    I'd like to ask for some advice regarding a strange issue I'm having with a Bizhub C35 machine. C35 thin horizontal lines.pdf
  • darry1322
    • Oct 2010
    • 817
    Re: Bizhub C35 random thin horizontal lines on copies
    If it's only on copies and not on print, fax, or internal jobs .... clean the glass.
    • tech51
      • 846
      Have seen similar faults a couple of times. Its always been the mfp board that's fixed it for me.
      • GOA
        • Jan 2017
        • 14
        The glass is clean and so are the laser windows under the imaging units. Can the mpf board be repaired or did you install a new one?
        • tech51
          • 846
          New board both times. Make sure if you decide to fit a new one, that you follow the procedure in the manual.
          • GOA
            • Jan 2017
            • 14
            One other thing that I've noticed this morning when I turned on the machine: It emitted a strange buzzing sound. The sound came from the side where the mfp board is mounted. The unit didn't start it didn't get past the logo.
