Firmware for Konica Minolta Bizhub C3110
  • homie
    • Sep 2025
    Hi,
    I am new here and my english is not the best.
    I need the newest firmware for Konica Minolta Bizhub C3110, because it is not possible to start air-print on this maschine. The maschine was built in 11/2014 and I have read, 2 month later it would be possible to integrate airprint. A hd-storage I have built in and formatted. But the menue for airprint is not shown .....
    Have anybody some help for me
    Thank you for your help!!!
    G
  • mdtrinh
    • Aug 2010
    • 68
    Re: Firmware for Konica Minolta Bizhub C3110
    Originally posted by homie
    Hi,
    G
    Here is from user manual, page 113
    - This function is available when an optional Hard Disk is installed.
    - To use the AirPrint function, your iOS terminal must be compatible with iOS 4.2 or later.
    - The AirPrint function requires Mac OS X (10.7 or later). For details, visit the Apple website.
    - To use the AirPrint function, your iOS terminal or Mac must be connected to the same network as this
    machine via Wi-Fi. For details on the iOS terminal and Mac network settings, refer to their relevant user's
    manuals.
    - The AirPrint function does not support the user authentication function of this machine. To use the Air-
    Print function in an environment in which user authentication is employed, set [Security] - [Authentication]
    - [General Settings] - [Print without Authentication] to [Allow] in the administrator mode of Web
    Connection.
    Hope this help
    • homie
      thanks for your help!We manually installed a HDD and formatted it with the options given by the admin-menu on the printer.
      Authentifications steps are fulfilled but there is still no section AirPrint listed unter network settings like I have it with a similar Konica Minolta printer featuring AirPrint.
      Requirements from iOS/Mac's are fulfilled too.
      Maybe a firmware upgrade is necessary? But is this even possible as a normal user, are special hardware devices needed to flash the printer? The firmware files are very hidden..
      -homie_son
