Bizhub C220 HDD Lock Code Reset
  • kahodges
    • Mar 2013
    • 24
    Bought a used bizhub C220 and the HDD failed. I put in a new SATA drive, and it's asking me for the HDD lock code. Is there a default or work around code? Or how can I reset or remove the code if I do not know it? I was able to get to a section to preform a format. It did not give me the option to run a logical format, so I ran the other option. Still is asking for the HDD lock password. Thanks in advance.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Bizhub C220 HDD Lock Code Reset
    See your other post and follow my suggestion.
    • graffitiartist7
      • Dec 2016
      • 6
      Run a physical format, reboot, run logical format, reboot, done.
      • kahodges
        • Mar 2013
        • 24
        The problem was that it would not allow me to perform a logical format. I did run the physical format. I spoke with a guy that works on these bizhubs quite a bit, and he told me to try 1 -15 as the HDD password. Ended up being 1-14+1, and that reset the password. I'm doing a logical format on it now.
        Thanks for the help.
