yellow drum unit is blinking , can i reset !!
  • JOEBOOROCKSYOU
    • Jan 2008
    • 85
    urgent!!!
    my customrs yellow unit just went on the fritz,
    can i reset this out in the field..please help.....
    thanks ,
    papa JO....
  • bigmark
    • Sep 2008
    • 39
    define fritz? bad copy quality? etc... if its actually doing something bad.... no sense in resetting it. just replace it.
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      IF the unit is giving the replace message, you can disable the lock out of the unit.
      If it's just on the fritz, try adjusting the horizontal and vertical hold.
      • JOEBOOROCKSYOU
        • Jan 2008
        • 85
        it says to replace , sorry for the bad description....
        • JOEBOOROCKSYOU
          • Jan 2008
          • 85
          is that in the service teck mode...?
          • ni311
            • May 2008
            • 658
            What machine is it?
            Konica Minolta Error Codes - Explanations and Solutions
            • JOEBOOROCKSYOU
              • Jan 2008
              • 85
              Originally posted by ni311
              What machine is it?
              sorry that would help....
              cf 1501 minolta
              • cobiray
                • Mar 2008
                • 1199
                Yes, it's in tech rep mode.
                • JOEBOOROCKSYOU
                  • Jan 2008
                  • 85
                  ok i'll check the service manual,
                  any particulars or sec. i should be looking at...?
                  or is it just pretty basic..
                  • JOEBOOROCKSYOU
                    • Jan 2008
                    • 85
                    can't find it, i have the field service manual , went into clear counters
                    and its telling me no on the drum units....
                    help....!!
                    • ni311
                      • May 2008
                      • 658
                      You cannot disable the lock out on CF series. You have to change the unit or reset the chip. Check out my signature
                      • JOEBOOROCKSYOU
                        • Jan 2008
                        • 85
                        yea, theres no way to do it...
                        i just emailed you off your website..
                        thanks for the info..
