C8000 spilling black developer and magenta toner
  • CKiiza
    • Feb 2010
    • 77
    Good day good fellows.
    Got this C8000, first it was spilling magenta toner allover the print as if broken charger, but the charger is new and intact. A quick swap with a yellow or cyan charger shows the chargers work fine there but magenta continues spilling despite replacement with new charger.
    As twist would have it, inspection of the HV boards didn't reveal much only that on closing this time round the black developing unit is spilling all developer when the machine starts adjustment. Switched the two HV/1-1 & HV /1-2 but the same spills are persistent; magenta toner and black developer.
    Currently going to check for cable continuity just incase something might be messed up somewhere.
    Otherwise Any pointers?
    Thanks in advance
    Re: C8000 spilling black developer and magenta toner
    has anyone messed with the developers? can you tell where the leak is coming from? a few more details would help us help you.
    • CKiiza
      • Feb 2010
      • 77
      The developer spills the way it was common with the black imaging unit in C650.
      the drum attracts developer off the sleeve roller and it attracts onto the transfer belt.
