Bizhub c351 NIC problem
  • Guest
    Hi there,
    I have a bizhub c351 with Firy ic402, it was not recognized by the machine NIC, when i tried to change the controller from "0" to "1" the machine hanged out for long time,ip address also cannot be changed i mean after changing the ip address of the machine a restart is required but when it restars there is no ips in the ip address bar, after flashing fw no use, the same issue is existing, is there any other fw for NIC or what i missing can any expert help please.
    Thanks in advance
