Konica Minolta C6000 with J-9451 can't duplex
  • gcalleros
    • Jun 2025
    [Jamming] Konica Minolta C6000 with J-9451 can't duplex
    Good afternoon all...
    Working on a new customer looking for help on a machine that has had an issue while duplexing. Simplex jobs are not an issue and print with solid image and little to no jams. A duplex job will jam at pre-registration of the 2nd side with an error code of J-9451 which points to PS23. In I/O check mode the sensor works without fail and with a slight touch. We have replaced the sensor and the actuator and the ADU Drive Board with the same issue. I would go for the Main PCB but if the sensor changes states I don't want to just swap components until I know what the failure is. I was thinking there might be an issue with either ADU loop motor (M57) or ADU reverse motor (M32) but can't remember if I checked those in I/O check mode.
    One funny thing I noticed is that the J-9451 doesn't show up in the Jam list of the Management List...
    Anyone see an issue like this? TIA
  • methogod
    • Dec 2008
    • 919
    Re: Konica Minolta C6000 with J-9451 can't duplex
    it is all the time or heavy stock only?
    • gcalleros
      It's all the time with different paper stocks and different sizes.
      • service_man
        • Jul 2012
        • 59
        Hello,
        CHECK THE MOTOR who turn paper on duplex A03U M111 00 HB Motor /50, and clean the SHAFT who turn on roller and transport papre for duplex and exit.
        That shaft is dirty.
        regards
        Shaft.pdf
