C308 + "ID and Print" + Y-Soft Card Reader
  • kmsamic
    • Nov 2016
    • 8
    Hello All,
    From the little bit of research I have done it seems like it is possible to setup "ID and Print" with a RFID Card Reader and no additional software. So a users card gets registered to his ID so that when he walks up to a device he just needs to scan his card to get access to his jobs.
    I know about these settings below...
    Authentication is set to "On MFP"
    Turn On "ID and Print"
    I have looked for a bit more of a detailed setup but can't find anything, can anyone assist?
    Thanks!
  • rrrohan
    • Sep 2011
    • 1977
    Re: C308 + "ID and Print" + Y-Soft Card Reader
    Enable and config user authentication on copier
    Set output method in driver to ID & Print with same credentials
    Thats assuming you didnt know how to set it up. If you already knew im sorry.
    • kmsamic
      • Nov 2016
      • 8
      Thanks @rrrohan
      I Wasn't 100% sure but thanks.
      I was also looking for confirmation that the it will work in the current config and that you do not require any additional options?
      Cheers
      • rrrohan
        • Sep 2011
        • 1977
        What card reader have you got/getting?
        Sent from my SM-G900I using Tapatalk
        • kmsamic
          • Nov 2016
          • 8
          It is a Y-Soft YSCR-3200 RFID USB Card Reader.
          • rrrohan
            • Sep 2011
            • 1977
            You install it ok and get it to work or u need help
            • kmsamic
              • Nov 2016
              • 8
              Hi rrrohan,
              Will get back to you shortly. Thanks for the help.
              • toshibaestudio
                • Jun 2016
                • 116
                IF Ysoft server & card reader is installed, u just need to register the compatible ID card to the respective users on the Ysoft server.
                • kmsamic
                  • Nov 2016
                  • 8
                  So there isn't any Y-Soft in the mix, its just the Y-Soft Card Reader, and hoping to use the local authentication on the MFP combined with "ID and Print"
                  • rrrohan
                    • Sep 2011
                    • 1977
                    Is the card reader installed?
                    If not you need the driver and to enable it as the authentication device
                    Unless you enable it in service mode you wont get the option when setting up user authentication to work with id and print
