Bizhub C454e: Stops when reaching its max capacity in booklet output tray
  • Methmann
    • May 2009
    • 72
    Hi mates
    We have a customer, which have an Bizhub C454e with FS-534 and SD-511 finisher.
    They are printing big booklet jobs. Where the little output tray on the saddle sticher, often gets full, and they need to empty it, when the machine stops before the job is done.
    On earlier models, could we just remove the output tray, and then, the machine could print forever. But we cant trick this model, its like its counting the booklets, it automatically stops when it have made like 10 booklets??
    So is there any way to maybe disable this counter?? So it keeps making booklets?
    Hope to hear from you :-)
  • HitMan
    • Aug 2015
    • 170
    Re: Bizhub C454e: Stops when reaching its max capacity in booklet output tray
    Have you tried unplugging the sensor so it doesn't get a full reading?
    • Methmann
      • May 2009
      • 72
      • Gaffers01
        • May 2011
        • 335
        I know this isnt helping but I have a customer with exactly the same spec but we have just taken the lower tray off
        and the booklets just fall into a box next to the machine.
        The only difference maybe is that they print A4 booklets (down to A5).
        • Methmann
          • May 2009
          • 72
          Removing the tray has also always been our standard solution, in these cases. But the machine stops anyway, its like its counting the booklets :-/
          Yeah, maybe the paper format can make a difference, our customer is making A3 booklets.
          • methogod
            • Dec 2008
            • 921
            Got to be a dip switch to turn that off...
            • micro switch dave
              Originally posted by Methmann
              Hi mates
              Hi, did you ever get this issue sorted? What's the outcome ?
              Dave
              • Methmann
                • May 2009
                • 72
                Dave
                No, i talked to a Konica Minolta technician, who said, it could not be changed, so that became a dead end :-(
