Konica Minolta Bizhub Pro 958
  • SPhillips
    • Feb 2017
    • 2
    Hi all
    I have just installed the above piece of kit.
    When Z-Folding multiple copies/prints the first 5 copies exit ok. The exit tray drives to an acceptable level momentarily but then drives all the way to the lower limit. Subsequent copies/prints just fall to the exit tray hap-hazardly. When the copies are retrieved from the exit tray it does not return to the home position until the power is recycled.
    The m/c config is as follows:-
    Bizhub Pro 958
    FS-537
    PK-523
    ZU-609
    RU-515
    F/W Versions loaded - G00-K7 and GC4-H0. I have tried both versions of the firmware and there is no change to the issue.
    It appears that the additional sensor bank fitted to the finisher is not registering at all
