Bizhub 1050
  • oakblue
    • Sep 2008
    • 15
    Bizhub 1050
    Does anyone know if it I can print to a 1050 without the touchscreen contol panel?
  • big jase
    • Jul 2008
    • 136
    you will be able to print,only problem i can see is setting up ip address on machine,with no display to follow
    If at First you don't succeed remove all evidence of ever trying!
    • ni311
      • May 2008
      • 658
      Another problem will be when you'll setup the paper type in different trays...
      Konica Minolta Error Codes - Explanations and Solutions
      • Itsthepaper
        Supervisor
        • Dec 2007
        • 91
        You can.
        There is a way to see the control panel on your computer and activate eveybutton as if your in front of the machine. I remember this from class i have never tried it.
        Love the Job Love the Work.
        • oakblue
          • Sep 2008
          • 15
          is there special konica software I need to do this??
          • mtp23451
            What is the way ???
            • Hemlock
              • 432
              If I recall correctly, there were 2 ethernet ports on the back/side of the 1050, one for printing/scanning and the other for Web Utilities, PS JobEditor, NetBackupTool and Mail remote notification system. They required 2 different IP addresses and, if configured, pointing a browser to the IP for teh web utility port/addy would allow control of a virtual touchscreen. You could make all your setting selections for paper and such, you just couldn't make it print/copy like this.
              Once paper settings are done, you should be able to send a job; just make sure it's set to release/print automatically and not go to a hold queue.
              It's been several years since I've touched one of these, so take this with a grain of salt.
              “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
              • redhotrob
                • 69
                You can use the machine nic, register your IP into the machine, then use remote panel.
                • Hemlock
                  • 432
                  Without a touch panel, is there any way to configure the NIC?
                  • RRodgers
                    • Jun 2009
                    • 1947
                    Yep, what he said.
                    • AVux07
                      • Oct 2007
                      • 57
                      How do I "register your IP into the machine" cause I'm getting a message to "Register Authorized PC's before using Machine Manager setting" when I try to edit user passwords on web utilities on a BH950, though I can get to the WU screen fine.
                      • MADSYS
                        • Sep 2009
                        • 10
                        Prior to use Remote Panel the machine administrator should register those PCs accessing through Remote Panel. Please review the POD Administrator's Reference User's Guide which you could download from Support | Konica Minolta Business Solutions, U.S.A., Inc.
                        Good luck
