I set the IP settings in admin mode to 10.98.251.100, subnet 255.255.255.0. G/W 10.98.251.254. (old IP ended in 5, possible conflict)
I can ping with 4 successful replies, bring up the embedded web page, but it will not print. I tried to create a new TCP/IP port with the add printer wizard but will not find it. Nor it is discover-able when searching network. I plugged the device directly in same router as pc to ensure there was not an issue with cabling/port. No luck, any help would be welcome thanks.
