Konica minolta bizhub c452 depletes developer (magenta & cyan)
  • AhmedChamumi
    • May 2016
    • 131
    Hi everyone,
    I have yet another bizhub c452 which habitually depletes magenta and cyan developers every 300 to 400 printouts....here is what i have replaced so far;
    1. Genuine imaging units
    2. Toner hopper unit.
    3. HVTs
    4. Printer control board.
    After replacing the above indicated the cyan has shown some improvement but magenta still misbehave.....what do i over look?
    Please assist.
    Best regards,
    Ahmed.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Konica minolta bizhub c452 depletes developer (magenta & cyan)
    I think there was a bulletin about the transfer unit grounds and connection on the back causing issues.
    Also check the Drum/dev unit contacts in the back of unit.
    • Max
      • Oct 2011
      • 563
      Replace belt,k dev and k drum. I found that fixes the problem.
      • REGSIS
        • May 2016
        • 435
        Besides HV board, this can be caused by any consumables which is overlife.
        For example overlife black drum can cause this problem on magenta IU.
        Do you have any warnigs after image stabilization on bottom of the screen like P-5 ?
        What are the values for Vg and Vb for each unit?
