C-3102 sur PRESS C6000
  • Shinigami
    • Mar 2017
    • 44
    [Error Code] C-3102 sur PRESS C6000
  • service_man
    • Jul 2012
    • 59
    Re: C-3102 sur PRESS C6000
    Hello,
    It's a problem in fuser unit gear with needle and shaft.
    Probably gear is dirty.
    You have 3 white gear and 1 shaft.
    Try to clean that, if the code been appears, you must change that.
    Regards!!!
    • Desert Rat
      • May 2008
      • 1089
      I just had that problem on a C7000. It was gear "M" the one with the one way bearings. Clean the shafts with scotch brite.
      I will also take a fine file and score the section where the bearing rides. I've seen them slip on shafts that are too smooth.
      DR
      • dimok
        • Aug 2017
        • 2
        i'm struglling with same code on c7000
        • Desert Rat
          • May 2008
          • 1089
          If memory services me, that is a fuser pressure code correct? There is a brake componet on the pressure shaft under the lower roller. This is suppose to keep pressure
          shaft from drifting. There are some one way gears in the front drive unit. Change those, 3 of them gear "M" are the same. Also check the pressure sensor in the front.
          As you turn the knob to cycle the fuser, you should notice that if you turn it one direction it turns easy and the rollers have space between them.
          Turn the know the other way and it should engage those gears and you will feel resistance as the rollers come together. At this point you should be able to see
          the pressure sensor flag block the sensor. With the pressure applied turn the knob the other direction and it should feel easy.
          Hope that helps
          DR
          • 61zm0
            • Mar 2012
            • 6
            Check the shaft on the fuser drive. It has 2 one way gears on the same shaft. I have replaced 3 of them because the one ways
            have so much pressure that they reduce the size of the shaft.
            Put a metal ruler on the shaft and you will see a gap.
            • Desert Rat
              • May 2008
              • 1089
              61zm0,
              Good observation, and I have seen the shafts in these type of bearing do just that.
              DR
