C450 Faxing
  • rasman67
    C450 Faxing
    I setup a C450 to fax using the instructions. When I go to use the fax it won't dial out unless I goto direct dial and select tone, then Dial the number. Then it is a crap shoot if it goes through or not. If I goto Direct and just dial the number the dial tone just keeps going over the speaker. If anyone can help I would be greatful. The customer is OK for now but thats now.
    Thanks in advanced
  • ni311
    • May 2008
    • 658
    Try formating your hdd, this solution solved my problem.
    • dogsbody
      • Jun 2007
      • 289
      before formating, backup your address book, user authentication etc. will save time later if they have a lot of users/scan locations.
      The force will be with you always.
