Bizhub C353 Cyan is missing
  • Gabriel
    • Jun 2006
    • 140
    Black, Magenta and Yellow colors are perfect but Cyan isn't printed out.
    Machine is clean, no codes, no warnings. It was printing fine
    Image units, fuser unit, transfer belt are 50% of its life,
    I swapped working Cyan Image unit >No Change<
    Cleaned slit glass >No Change<
    Running out of ideas. Any help is welcome
    PS:
    printed Test page is missing Cyan too.
    Laser unit block ?
    Firmware ?
    • 14755
    Re: Bizhub C353 Cyan is missing
    There must be a P code. Oil can on display?
    If a known good UI doesn't fix it I would try a good HV power supply.
    • Gabriel
      • Jun 2006
      • 140
      copier addict
      Thank you for your fast respond.Anything else may cause this issue?
      Customer is 70 miles from office (140 miles round trip)
      • mrwho
        Major Asshole!
        • 4299
        Had a C250 long ago with exactly the same problem - was the laser unit ever-so-slightly tilted out of position, enough that the laser wouldn't reach the drum.
        Mascan42
        Ibid
