Konica C220 User Authentication
  • jonbonse
    • Jun 2009
    • 730
    Hi all
    I am about to setup user authentication for copier usage on a couple of C220's.
    There are quite a few accounts to setup and wanted to create an excel file to take with me and simply upload it to save time manually entering on site.
    I know of PageScope Admin but it won't allow me to create a file unless i am connected to the printers....
    Is there a way i can import an excel file or csv file to upload once on site?
  • B0265
    • Jan 2007
    • 718
    Re: Konica C220 User Authentication
    If you install the PS data admin at the customers site you can import a csv file.
    • jonbonse
      • Jun 2009
      • 730
      Thank you
      Would I be able to export a CSV file so that I can get the correct layout for the CSV file itself question
      • emujo2
        • Mar 2017
        • 1580
        It's pretty simple, arrange your columns with
        ACCOUNT NAME|ACCOUNT NUMBER, or AUTHENTICATION NAME|PASSWORD
        Make sure you keep 1st, last name in same column as PSDA only lets you pick name.
        When you run the import wizard you simply designate which column is the name, and which column is the account track or password.
        Account Track or User Authentication must be enabled on the device before you can import this file. Emujo
        • jonbonse
          • Jun 2009
          • 730
          Success!
          Is there a way to report in PageScope on user printing so it can be exported to excel?
          • kmtech200
            Yes you can do that.There should be a option to export on the interface when you are logged in as administrator.
            • jonbonse
              • Jun 2009
              • 730
              Thanks but I can't seem to find it...
              I even searched export in the search menu but nothing was listed.....
              • B0265
                • Jan 2007
                • 718
                You can use data administrator for this also. In the user authenications settings select file > export > "save the user list in the tab text format"
                • kmtech200
                  Let me try it and I will revert back to you.
