Konica minolta bizhub 421 error code C2202
  • Dilahk007
    • Apr 2014
    • 7
    [Error Code] Konica minolta bizhub 421 error code C2202
    Hello, please i need help with my bizhub 421. Actually it always shows a system error code C2202, I tried to fix the problem by changing the motor M1 and the drum kit and also the developer kit but it still didn't work and the error code often shows up. Please if it had happened to anyone of you help me to fix it. Thanks in advance.
  • Iowatech
    Not a service manager
    • 3930
    Re: Konica minolta bizhub 421 error code C2202
    You will likely be better served if you posted in the Konica Minolta forum:
    http://www.copytechnet.com/forums/konica-minolta/
    That is where most of the KM techs can be found.
    Good luck!
    I apologize for not being able to provide immediate help, I've only worked on analog Konica machines and don't know the new error codes.
    • CraigW
      • Dec 2010
      • 417
      Check the brown felt seals (4) at the ends of the drum. If not careful they will peel loose, roll up and bind the drum.
      • Dilahk007
        • Apr 2014
        • 7
        I changed the entire kit but it still didn't work so i made some research and people told me that the cause may be in the drum motor M1 printer control board (PRCB). Could i adapt the motor speed from the machine itself?
        • CraigW
          • Dec 2010
          • 417
          Look for motor with same part #... and swap the 2 for testing.
