Case in C8000
  • Shinigami
    • Mar 2017
    • 44
    Case in C8000
    Hello !
    I have this problem in C8000
    the fusing belt is changed
    thanks for your help
  • Shinigami
    • Mar 2017
    • 44
    Re: Case in C8000
    Originally posted by Shinigami
    Hello !
    A big problem so ?
    • snoopyed
      • 8
      Re: Case in C8000
      How many print counters with lower fuser belt unit ? In my case, this image problem will show up when the lower fusing unit is not so good. Some times this problem can not be solved even I replace both fusing roller and lower fusing unit. I thought it is a kind of cancer belong to C8000.
      從我的iPhone使用Tapatalk 發送
      • methogod
        • Dec 2008
        • 921
        Re: Case in C8000
        you changed the belt, did you changed the upper and lower fusing rollers?
        • Copyshopnis
          • Apr 2013
          • 6
          Re: Case in C8000
          Hello !
          Hi, did you solve this problem with fuser on konica
          • JP1
            • Jul 2012
            • 7
            Re: Case in C8000
            Had this when I,ve replaced lower fuser belt & comes back in a few thousand copies later had to replace the fuser, must get worn metal plates around lower belt area.
            You can get metal shimes from Japan -did not work for me.
            • JP1
              • Jul 2012
              • 7
              Re: Case in C8000
              See Doc, if fuser has done 5 million replace it
