DI351 C13D0
  • CBS1
    • Aug 2025
    DI351 C13D0
    I know this code is eprom malfunctoin but what does that mean?
  • Scott_Lewis
    • Mar 2007
    • 519
    Never had that malfunction. Looks like there is a failure to communicate with the eeprom for some reason. The manual says
    1. Reset the malfunction, turn OFF and ON the Power Switch, and unplug the
    power cord and plug it back in.
    2. Check the connection between IC3 of Master Board and EEPROM.
    3. Change Master Board.
    4. Change EEPROM.
    I'd check all the cables, reseat connectors and the prom before replacing any components.
    • redime
      4. Change EEPROM.
      Exactly, reseat all the connectors before trying to replace stuff
      • kmcopytech
        • Dec 2007
        • 141
        Chip is 93C46, which can be copy.
