Driver bizhub 210
  • marexim2000
    • May 2017
    • 16
    [Misc] Driver bizhub 210
    Do you know if existing or have somebody a driver for windows 10 for this bizhub 210? There is not on any konica minolta site. Is there a win8 x64 but not worked.
    Thanks.
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    Re: Driver bizhub 210
    Thanks.
    Hi. You can try the bizhub 211.It was the upgrade for the 210. So it is newer and drivers supported.
    Make sure to choose the GDI driver, because on both machines PCL was optional and needed a board.
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • marexim2000
      • May 2017
      • 16
      It does not work.
      • REGSIS
        • May 2016
        • 434
        GDI driver win8 x64 for bizhub 162/10 is working fine on Win10. Tested on several machines. Do not use driver for 163/211!
        As mentioned above make sure that you download (latest) GDI version - NOT PCL!!!!!
        • marexim2000
          • May 2017
          • 16
          I instaled GDI no PCL win8 x67 but no work. It look like a good installation, without erorrs but when I try to prin on the printer blink green light printer an light read on "Fount" remains on.
          • REGSIS
            • May 2016
            • 434
            I really don't understand last part of your post, but according to the first part machine is receiving a print job.
            If you mean that error message is displayed on screen press printer button (next to the green light) and read what error is it (usually wrong paper format). From here you can delete print job by pressing stop (red) button.
            Make sure that you select (in printer preferences -on driver) same paper size as you put in paper tray.
