BizHub C454 finisher removal
  • Staggan
    • Jan 2017
    • 54
    Hello
    I have removed the finisher and bridge unit from a C454 and replaced the cover for paper exit.. but there is also a sing arm / guide that also needs to be put back...
    I cannot find any pictures in the manual regarding how this triangular guide fits....
    Can anyone help?
  • emujo2
    • Mar 2017
    • 1579
    Re: BizHub C454 finisher removal
    post a pic of the piece. Also, there is an exit sensor that needs to be removed. This sits on top of the fuser exit area. Emujo
    • Staggan
      • Jan 2017
      • 54
      Hello
      This is an image of the guide / arm...
      • emujo2
        • Mar 2017
        • 1579
        • Staggan
          • Jan 2017
          • 54
          I can kinda see where it goes, but can't see what happens to the other parts that are there...
          I can't find anything in the parts manual.. and waiting for a copy of the service manual at the moment....
          I think I know the sensor you are referring to, but there are two swinging arms that are, I think, above where that guide goes... not sure what happens to those...
          • allan
            RTFM!!
            • 5462
            Jip.
            Whatever
            • emujo2
              • Mar 2017
              • 1579
              That sensor needs to come out, it's only used when a bridge or job separator is installed. Just remove the small cover and you'll see the connection and screw. The sensor assembly sits on top of the fuser exit section. Emujo
