B950- Error code 6718
  • rietz
    • Mar 2017
    • 7
    [Error Code] B950- Error code 6718
    Good day team. My B950 is giving this error code c6718 and i need solution. the machine keeps jamming and shuting down after maybe 100 copies
  • mthomasebs
    • May 2017
    • 65
    Re: B950- Error code 6718
    Code
    C-6718
    Description
    The PVV is turned ON before the initial APC start processing is completed.
    Causes
    Confirmation of the wiring harness and the connector Reinstalling firmware Write unit Overall control board (OACB) Printer control board (PRCB)
    • rietz
      • Mar 2017
      • 7
      B501. ADF Failure
      The ADF of B501 is not responding. I tested it on another machine then it worked. I checked all the boards in the machine and the connectors. The control board is the only board that was found not responding when tested on other machines. Please help me, what could be the problem with the board and what is the solution?
      • mircea
        • Feb 2014
        • 70
        Re: B501. ADF Failure
        Best thing you can do is check all ICPs on that board for continuity
        Get a multimeter set it for continuity and chec if all ICPs are working.
        Search that bard for components with icp written next to them.
        There is a high chance for a blown icp .
        Good luck
