c3351 locking up?
  • def1603
    • Aug 2025
    [Misc] c3351 locking up?
    New c3351's locking up (control panel frozen/garbled) non-responsive . Occurring when sending print jobs to it while in sleep mode..or not...also when scanning to email. Rebooting can alleviate issue, temporarily..but may need to be done multiple times. When onsite, tech cannot replicate, but this is occurring way too frequently. Also false paper jams from tray 1. (the only tray on these machines) No bulletins available. FW is current. Machine has been checked as far as it can be. Any ideas out there?
    THX All.
  • emujo2
    • Mar 2017
    • 1579
    Re: c3351 locking up?
    This device is still pretty new to the line up, you may want to start by disabling sleep modes, no new firmware updates yet. Emujo
    • REGSIS
      • May 2016
      • 435
      I would set weekly timer option to OFF, not disable sleep mode.
      Weekly timer turns OFF machine at set time (auto erp) -orange light not blue and no print job cannot be received.
      Maybe this is not a solution to your problem but I recomend that you do that just in case since tech could't recreate the problem (and maybe that's why - it only happens at set time).
      Panel freeze -if they said so -(which can be resolved only by main power ON/OFF) should direct you that problem is network related.
      Solutions:
      1. FW update (wait for next one)
      2. Check for computers which have problems with network. I had one recently with problematic LAN adapter which froze machine's NIC one or twice a day and no print or scan jobs cannot be executed until hard restart.
      3. Let IT check network switches and network trafic for broken packages.
      4. Also check if IP telephony is on the same network as PCs and machine. If yes that can cause machine to freeze.
      • mo0651
        • 1054
        Does it have the same "flakey" memory chip in it?
        • B0265
          • Jan 2007
          • 718
          If you refer to the eMMC board so yes, I think it's the same as in the 7 and 8 series.
          • mo0651
            • 1054
            On the c3350-c3850 series there was a bulletin on the UK211 chip, causing lock ups. Haven't seen one of these critters yet.
            • def1603
              Thanks for all the info. I will be implementing these suggestions to see what happens. Will keep you all posted!
