BizHub 3510i PaperJam
  • woldsl
    • Jul 2025
    Hi ,Everyone ,Hope you are doing good .I am experiencing problem with my konica minolta bizhub 3510 ,Peper
    jam in right draw .Any idea ? .Thanks
  • Gab
    • Aug 2015
    • 671
    Re: BizHub 3510i PaperJam
    [ATTACH=CONFIG]36923[/ATTACH][ATTACH=CONFIG]36924[/ATTACH]
    registration clutch.
    • Hansoon
      • Sep 2007
      • 3388
      Machine good use a good clean up too and by doing that I would inspect the bushings of the upper and lower synchro rollers. Bet that they are gummed up.
      BTW, no need to replace the synchro clutch. Just blow it out with air, than flush it with brake cleaner or the like and blow it dry with air again.
      Hans
