C368 series ticking noise from fusing unit
  • avecosat
    • Jun 2012
    • 304
    #16
    Re: C368 series ticking noise from fusing unit
    Originally posted by Matt
    I have had this same issue , I tried a new fuser but it did not resolve . The trick is to remove the covers and adjust the small tension springs on each end of the fusing unit . This worked for me .
    I have had the same issue , What spring is it you say? thanks
    • Ashbell
      • Sep 2017
      • 17
      #17
      Hi guys, apologies for commenting on a "dead" post, but Konica Minolta have recently released a tech bulletin about this issue. If you have a service login you should be able to find the document on CSES.
      • avecosat
        • Jun 2012
        • 304
        #18
        Hi ,you could give me the bulletin number I can not find it thanks.
        • 907tec
          • 434
          #19
          Man, Konica's site is the worst. I am not able to find a bulletin regarding this, either. Any chance somebody could post the Ref#?
          • FXHO
            #20
            • Bix
              • Apr 2018
              • 1421
              #21
              Hi, I had the same problem in a new series machine and with a few pages (10,000).
              The fuser made a little noise. This is quite normal and happens in some cases. Just wait for a few copies and the noise will disappear with time.
