IC-401 Fiery Web tools problem
  • B0265
    • Jan 2007
    • 718
    Does anyone have problems opening the Fiery Web Tools on a IC-401(C350) from Firefox 3?
    Our customer have two Mac computers running 10.4 and when you try to open the Fiery Web Tools, you get the message "opening the java applet failed".
    Firefox version is 3.0.3.
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Could this possibly apply?
    Solution ID
    TAUS0800149EN* Solution Usage 8
    Description
    Solution
    CAUSE: Java update version 6 was installed during an OS update. Java update version 6 is incompatible with the current version of Command
    1.Remove the previous version of CWSME.
    2.Decompress the Mac_User_SW_CWSME_1_5_0f25.zip file tothe desktop.
    Follow the installer dialog by entering the appropriate responses for user agreement and installation. Installed CWSME version is 1.5.0f25 andinstalled
    SPECIAL NOTE : Solution contribution by Bill Ehmke, ESS/SSD andIan Lynch, Production Print/SSD
    Solution ID
    TAUS0629424EN* Solution Usage 3
    Now into Ip TV KODI Boxes
    • Specilist KVN
      • Sep 2008
      • 79
      Is deffinately a Java issue.
      On older machines you can have this issue running the applets on newer versions of java.
      Have you tried other browsers?
      Fierfox 3 is pretty new, that could also be giving you the problems.
      That or it is a security/firewall issue, maybe it is not alowing the applet to run as the Fiery commonly gives certificates that are not trusted.
      If you have a Windohs machine available you can try running the setup through there via Command Workstation.
      Unfortunately the Mac version does not have the server setup option.
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        It's a JAVA issue. I haven't seen it with these specific circumstances, but try updating the JAVA plug in.
        • buster68
          • Nov 2008
          • 181
          If you can find an original user software disk for the IC401, load the version 2 java runtime environment. The older controllers are not compatible with the new java esp. version 6.
          • B0265
            • Jan 2007
            • 718
            Thanks, will try that.
