8050 error SC45-20
  • Rev
    • Aug 2025
    8050 error SC45-20
    What does this error code indicate? The fix?
  • ni311
    • May 2008
    • 658
    It is something about color registration abnormality, hope this help.
    Konica Minolta Error Codes - Explanations and Solutions
    • Juxta5
      • Jul 2008
      • 65
      SC45-20
      Color registration correction results in abnormality.
      Color registration marks for each color are transferred on to the transfer belt during this process. The locations are detected by the color registration sensors. This information is used to determine the "image drift" amount for each color.
      Possible replacement parts:
      Color Registration sensor/Front (operation side of machine) (PS8)
      Color Registration sensor/Rear (non-op side) (PS9)
      Worse case scenerio: Problem with Printer Control Board
      Maybe someone has some methods for cleaning these sensors instead of replacing them...
      • laserman06
        Conservative in Exile
        • Dec 2007
        • 323
        Could be caused by the transfer belt walking to the front of the assy. So pull it out and check. Also, go into service mode and run halftone test pattern on all colors. Make sure sheets come out covered completely with all colors.
        The family that prays together, stays together!
        Smile God created you and He doesn't make mistakes!
        Relax, God IS in control!
        Be still and know that I am God
        Ps 46:10
        • DaveTech
          • Jul 2008
          • 9
          Hi,
          I have had this problem before sometimes that code 45-20 can be caused by other things so it be worth while turning off the color registration sensor from the dip switchs in 25 mode and see if you can get the machine to start up.
          • redime
            Search in the PDF
            • Rev
              SC45-20 solved
              Thanks to all for advice. Once I recharged all four developers the SC45-20 went away.
