Hi there,
I have a different one here. What is happening is the customer does the two staple about 90% of the time doing books. So what is happening is that it will staple on the back part of the page, the stapler moves to the front and it stops and then the paper gets pushed up about an inch and the it pops the J-7281. In the I/O we checked PS43,29,27,22 and 6. We switched PS22 and 6 around with the same result. This customer has 2 BH1052's both with a FS-532. So we switched the staple heads with the same result. We have redone the firmware and upgraded the finisher firmware to 71. Still the same thing. It can corner staple all day. We staple the narrow setting, still the same thing. KM says to check wire harness and that looks okay. So we are left with the Finisher Control Board. The thing about this is that it does it every time. Just pounding our heads against the wall. Just wondering if the Control Board is the right direction.
KEN
KEN
