ADF Initialization Error on Bizhub C35
  • Shipley429
    • Aug 2017
    • 4
    I have a Bizhub C35 that I have changed out MFP and SSD per Konica with a error code C023. Come to find out that it was a bad SSD card. Didn't need the MFP but replaced it anyway. Machine is up and running good except after startup I keep getting an ADF Initialization Error. Researched SSD Home page on Konica, also the Service Manual with no results. Any help would be great! Thanks!
  • Shipley429
    • Aug 2017
    • 4
    Re: ADF Initialization Error on Bizhub C35
    I also changed out feed assy, cleaned all sensors, rebooted machine with same issue. I have a scrap machine so might as well change out whole scanner.
    • REGSIS
      • May 2016
      • 435
      Do Firmware update first and if problem persist then check cable connectors and/or change adf board or whole adf since you have another machine.
