Have a Konica c360 that about every 8 copies it will stop and give you the internal error code c2557. I put a black drum and developer unit from another working copier and it and still get the c2557 after 7 copies. I thought for sure changing the developer unit would take care of it. Is there something else it could be. Thank you
Konica c360 c2557 code
Re: Konica c360 c2557 code
i have two c360 machines that thru this code today
the one i went to i ran stabilization and initiailization and it cleared and function before doing that i ran manual toner add for black( you must open front panel to stop adding)
but i wasn't sure if it would stay fixed that is why i was looking this up and saw your post
we did have thunderstorms the other day and i thought that may have contributed to problem
have not gone to the other c360 yet -
I ran the ad toner then did stabilization and then initialization and it finally worked after I did it 3 times. Now when I hit the fax scan button it just beeps at me and nothing happens when I reinitialize the machine reset the data I must have changed a setting to cause the fax scan not to work. I am not very familiar with the faxs part of the machine can anybody tell me what I might have to reset in order for fax scan to work againComment
Thank you. That workedComment
