Konica bizhub 350 touch screen not working
  • DOE
    • Mar 2010
    • 258
    A Konica bizhub black and white 350 that the touch screen will not work. I was able to do the sensitivity adjustment and get it to work for a day or so and it quits working again. Was told one time that you can just replace the piece of glass on the top and don't need to replace the whole panel. I just wanted to double-check that that was true. Thank you
    • 14754
    Re: Konica bizhub 350 touch screen not working
    Yes, you can replace the touch screen. You can get the OEM part, or you can get an aftermarket screen for about a third of the price. Pretty easy to change.
    • Cookr
      • Dec 2011
      • 184
      They are actually pretty easy to repair also. Ive done probably 50 in my time and I would say most of them still work but we don't really have many of those machines left out there.
      You basically just have to take it apart pull off the FPC ribbon that connects to the glass, clean up both connections and reattach with some kind of electrically conductive adhesive. I pretty im sure i bought it in a two sided tape form from amazon and then its good to go but thats up to you lol
