set time of a bizhub 450
gduTags: 450, alta, bizhub, bizhub c253, bizhub c35, fax, fuji xerox, pushed, question, set, system settings, time
lmt1979
Change time on a 450
to change the time you just need to enter into Administrator mode
something like User Tools, Admin Mode
the default password is either 12345678 or all 0's (zeroes)
then, just look for timer settings. -
gdu
HS_Gal
bizhub C253 Set Clock
Our office has the BizHub 253 and after the time changed for daylight saving the fax was off by an hour.
To fix it we pushed the Utility/Counter button
Selected Administrator Settings
Used the password 12345678
went to system settings and there was a Daylight Saving function we switch on.
This is also where you would change the time.Comment
