Konica Bizhub C353
  • freedom10101
    Konica Bizhub C353
    Our Company has brought Multifunction Printer Konica minolta C353 with fax kit FK-502 and MK-711 Mount kit. We have an ip fax fine and using Cisco ATA converter to connect with analog fax machines.
    The standalone fax machines are working with ATA device but the particular model doesnot reciving the incoming FAX but can send the fax. Error code is "R16"
    I heard if can make baud rate below 9600 it may recieve. this issue facing in lot of officess in our place.. please assist to solve the issue
    Thanks in advance
