Konica Minolta 1050E with SC36-06, changed TH3 and TS2 can't get rid of code
  • Eleshuvio
    • Jul 2025
    [Error Code] Konica Minolta 1050E with SC36-06, changed TH3 and TS2 can't get rid of code
    Replaced TH3 and TS2, Turn on service mode and it shows 3-0 not 3-1, doesn't matter what I change it to it still throws the code. Kida stuck at this point, any help would be appreciated.
    Thank you,
    Dave
  • tulintron
    • Jul 2014
    • 668
    Re: Konica Minolta 1050E with SC36-06, changed TH3 and TS2 can't get rid of code
    Thank you,
    Dave
    Check the I / O check if the thermistors are measuring correctly.Make sure the heat sinks are open.
    Check switch DIPSW 03-1 = off
    Check behind the ACDB, electrical components that cause fuser error codes.
    • mircea
      • Feb 2014
      • 70
      Thank you,
      Dave
      Check fuser back conector for any dmg. Also there might be a fuse blown on your acdb or prcb. You can check all fuses for continuity with a mutimeter. Those fuses are noted with ICP on the board.
      Best of luck
      • allan
        RTFM!!
        • 5462
        I had i similar problem on a B1250. Could not get it to work until i changed the funny looking one from a B601.
        Whatever
