C554e with C2152 error
  • jwrycza
    Office Systems Expert
    • Sep 2013
    • 88
    I have this machine with this error code. Originally, the code would set only on color printing but, now, it is constant. I have replaced the fuser drive unit (That is where the motor and clutch are), PRCB board, power supply unit and HV unit. All with no change. Looking for some insight into this.
  • AjitN
    • Mar 2009
    • 287
    Re: C554e with C2152 error
    I think C2152 for ITB retract problem.
    Try to clean retract sensor and check retract mechanism.
    Hope this helps
    • selig67
      • May 2008
      • 156
      • mo0651
        • 1054
        Did you change the transfer belt?
        • jwrycza
          • Sep 2013
          • 88
          No, I have not. It is a wiring issue as I am losing voltage to the relays.
          • copierwhisper
            • Mar 2013
            • 78
            Ultimately what was wrong and/or what was the fix?
            • copytech,mike
              CopyTech,MIKE
              • Jun 2014
              • 258
              Replace the transfer belt unit!
              • allan
                RTFM!!
                • 5462
                Its normally toner on the sensor...
                Whatever
                • Copier repairman
                  • Aug 2019
                  • 86
                  Remove the transfer belt and clean the sensor.
