DI 2510
  • Gab
    • Aug 2015
    • 671
    DI 2510
    ADD toner message. MAchine turns toner bottle. EWhen it turns toner bottle it doesn't sound as it normally is.
    Do i have to check the toner add mechanism or something else?
  • srvctec
    Former KM Senior Tech
    • Oct 2009
    • 827
    Re: DI 2510
    First check that the bottle is installed correctly.
    Could be bent shaft on toner add drive assembly. There was a bulletin to remedy the issue many years ago. They made the base of the shaft much wider for better support on the frame.
    Yes, you'll need to tear it apart to find out what's wrong.
    Edit: If it keeps adding toner, the sponge on the toner add solenoid has deteriorated, causing the solenoid to stick. But if this happens, there should also be an overtoned developer code, eventually.
    Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
    • antone
      • Oct 2014
      • 344
      Re: DI 2510
      Toner drive gears Assy...broke.....this happens when they jam toner bottle in wrong
      Sent from my SM-N920V using Tapatalk
      • Gab
        • Aug 2015
        • 671
        Re: DI 2510
        Finaly i removed cover and checked gears and toner hopper. I noticed that gears rotate well, the gear that turns toner bottle rotates ok and isn't loose. But the bottle doesnt rotate allthough the gear rotates. And of course message "add toner". Any idea ?
        • mo0651
          • 1054
          Re: DI 2510
          Can you see the solenoid fire and release the drive gear for bottle??? There might be a pin thru that gear for drive.
          • antone
            • Oct 2014
            • 344
            Re: DI 2510
            Mark toner bottle....then pull out drum/DV...unit chk...to see if toner is added
            • Zesti
              • Jun 2009
              • 308
              Re: DI 2510
              Chech ur toner bottle. Which one r u using. If that's TN311/211 it will rotate but not feed toner as toner droping hole positions r at different palce.
              • Gab
                • Aug 2015
                • 671
                Re: DI 2510
                I used 2 toner bottles. Both are for 2510 (different manufacturers) Also one is used widely in other (and in this machine) with no problem.
                I removed the covers and revealed the toner hopper . MAchine tries to add toner , gears rotate , also the gear that turns toner bottle , turns ok. but toner bottle doesn't. Also i noticed that is dropped around the hole also i see no toner in developer unit hole.
                • antone
                  • Oct 2014
                  • 344
                  Re: DI 2510
                  Replace toner drive Assy....99%
                  • brent
                    • Nov 2008
                    • 1214
                    Re: DI 2510
                    antone is right.. I gurantee it is the toner add/ add assembly it might be still available from Minolta.. the machine is several years old now though
                    brent
