No Display after replacing DV drive assembly
  • methogod
    • Dec 2008
    • 917
    [Electrical] No Display after replacing DV drive assembly
    Pulled boards and vertical support to replace DV drive assembly.
    End result is machine boots but no display. Red light with sub power off, Green light and boots trys to start and initialize, but we assume its failing because of LCD failure.
    Pulled LCD and harness from 2nd C6501 and tested with no change (or display). Replaced and works fine on other machine. ( so that eliminates LCD and harness)
    Machine has high volume around 5M so i had a used (low meter) High Voltage Board which we swapped while the OACB and PRCB was out, same results. Replace with known good used board, same results.
    DV drive was replaced because Cyan DV was slipping causing all sorts of random issues.
    Any suggestions how to test without a display, we are going to check voltages and outputs - hoping just a pinched or damage voltage line.
    Any one have the ICP list for the boards (checks for this issues specifically).
    1st correct Solution get drinks on me - seriously no joke.... good for beers, wine, or weed - whatever you want or ill donate it in your name....
    ***yes sub power is on***
    ***finishers and LCD should not effect LCD to turn on***
    ***checked all connectors twice, if not 3 times***
    thanks,
