Olivetti MF454 LDAP IC Card Authetification
  • marcohald
    • Oct 2017
    • 4
  • B0265
    • Jan 2007
    • 718
    Re: Olivetti MF454 LDAP IC Card Authetification
    Hi,
    Have you found any solution? I'm struggling with setting this up on a Bizhub C227.
    • B0265
      • Jan 2007
      • 718
      Perhaps this will help in your case:
      IC card ID format
      The format of the card ID, stored on the LDAP server, may differ from the card ID, processed by the MFP. By default, the MFP will truncate 2 characters at beginning of the card ID, as well as some characters at the end of card ID. Only the middle part of the ID will be used to authenticate against the LDAP server. This card ID format may not match to the ID format already stored on the LDAP server. In order to enable the MFP to send the full card ID to the LDAP server, a DIP SW has to be configured on the MFP accordingly. (MFP service mode)
      DIP SW 135
      hex 00 : card ID will be trimmed
      hex 01: full card ID will be sent from the MFP to the LDAP server ( without trailing "F")
      Example:
      In this example, a Ysoft Legic card reader is connected to the MFP
      Card ID read by the card reader: 3841394241353134FFFFFFFFFFFFFFFF
      Card ID sent from the MFP to the LDAP server:
      DIP SW 135 hex 00 : 41394241353134ff (MFP default setting)
      DIP SW 135 hex 01: 3841394241353134
      • tonyligz
        • Jun 2008
        • 26
        I need (KM) usb reader change usb keyboard emulation card reader(for xerox) tool,please sent to mail 405173825@qq.com ,thank you!
        • marcohald
          • Oct 2017
          • 4
          Hi,
          we have tried the Switch 135 but it does not resolve the Problem.
          The String is still at the same length truncated.
          Our supplier has orderd a Elatec TWN4 MultiTech SmartCard which should have a driver.
          I will report any progress.
