we have a Muratec MFX-C2880E..I think the bizhub 284e is the same machine...can someone confirm?... sometimes when the machine is producing copies, it will stop and give the "replenish paper" indication (there is paper in the tray)... if all you do at that time is apply slight pressure to the front of the tray, it begins working again...anyone have a solution to this problem?...thanks for the help...
replenish paper indication
Re: replenish paper indication
we have a Muratec MFX-C2880E..I think the Bizhub 350 is the same machine...can someone confirm?... sometimes when the machine is producing copies, it will stop and give the "replenish paper" indication (there is paper in the tray)... if all you do at that time is apply slight pressure to the front of the tray, it begins working again...anyone have a solution to this problem?...thanks for the help...
Sent from my Mi A1 using Tapatalk
