c7000 duplex registration drifts randomly
  • zubinn
    • Sep 2017
    • 51
    [Misc] c7000 duplex registration drifts randomly
    i have a c7000 machine if you print 100 sheets it will duplex okay.
    if you print a longer run maybe 500 sheets, within the 500 sheets there will be random sheets where the duplexing is off, drifts randomly 5mm.
    i believe it is a mechanical issue. and it is only on the duplexed side. registration for simplex is fine.
    what should i be doing. some check list to systematically figure out what needs to be changed would be very welcome.
  • habik
    • 2013
    Re: c7000 duplex registration drifts randomly
    Have you tried adjustments on duplex reg loop?
    Sent from my Mi A1 using Tapatalk
    Firmwares HERE
    • Tech Helpdesk
      • Jul 2015
      • 112
      Check the duplex registration plate, if it worn it will cause wondering registration issues
