C3350 Code 9401
  • jrf
    • 142
    C3350 Code 9401
    Hi
    Has anyone found a solution for code C-9401 on the C3350 model without replacing the complete scanner unit.
    the fault is probably due to the lamp or ccd but these are not available separately.
    Thank you
  • B0265
    • Jan 2007
    • 718
    Re: C3350 Code 9401
    Replacing the flat Cables in the scanner unit have solved this for us.
    • jrf
      • 142
      Re: C3350 Code 9401
      Thanks for reply.
      We changed the cables 4 days ago and no code since.
      • mrwho
        Major Asshole!
        • 4299
        Re: C3350 Code 9401
        Good afternoon, guys.
        Sorry to hijack this thread, but can someone please provide me with the flat cables part number? I can't find it on the parts manual - the scanner unit comes up as an entire assembly...
        Thanks!
        Mascan42
        Ibid
        • tsbservice
          Field tech
          • 7986
          Re: C3350 Code 9401
          Thanks!
          Try keys 23&24
          A121PP0Q00 Flat Cable 18P
          A121PP0P00 Flat Cable 24P
          • mrwho
            Major Asshole!
            • 4299
            Re: C3350 Code 9401
            Try keys 23&24
            [ATTACH=CONFIG]43763[/ATTACH]
            Thanks. My manual must be outdated - that doesn't appear in mine
            Thanks again!
            Mascan42
            Ibid
            • Kent
              • Feb 2018
              • 17
              Re: C3350 Code 9401
              Originally posted by jrf
              Hi
              Thank you
              they came out with a new style scanner belt the ends were brass new ones stainless, changed the belt slightly
